Power & battery settings in Windows 11 won't open
Reported
2023-10-02T14:41:09+00:00
The power & battery settings won't open when going to Settings >System > power & battery. The same thing happens when I right click the battery icon (power & sleep settings) in the sys tray.
    2024-01-07T10:39:28+00:00
    Снова включите «Службу датчиков» в Службах. Это мгновенно исправляет ситуацию. Новое обновление отключило эту службу по какой-то глупой причине. Наслаждаться! 👍
  2. DaveM121 932.6K Reputation points Independent Advisor
    2023-10-02T15:14:52+00:00
    Hi, I am Dave, I will help you with this.
    1
    Open Device Manager (accessible by right clicking your Start Button)
    Expand the Batteries section
    For each device in that section:
    Right click and choose Disable
    Wait a couple of seconds and right click and choose Enable
    Close Device Manager
    2
    Open Command Prompt, then run this command to open the Power Troubleshooter and run that
    msdt.exe -id PowerDiagnostic
    3
    Then check if you can open the Power and Battery section in the Settings app.
    2023-10-02T15:36:26+00:00
    Thanks for your quick response! Unfortunately, I followed your instructions with no luck.
    2024-01-07T12:30:23+00:00
    👍🙂Thank you. Worked great.
    2024-01-08T00:27:13+00:00
    As Илья Богданчиков stated, turning on the SensorService solved the problem immediately. It was disabled when I checked the services. I changed its property to automatic, and also right click, started the service.
    Thanks for this information.
