- Navigate to "Config" > "Software". Pop up box named "Keyname" should appear. Enter '1234' as keyname. Box will close after complete.
it says: The process cannot access the file because its being used by another process.
any solution?
I have a Windows 11 laptop. I inadvertently locked the laptop when I logged into my Microsoft Account and it showed the device was located in a different part of the Country from where I am located. After locking the device, I realized it was my personal laptop (in my possession, not where it was shown to be on the map). I am now trying to unlock it but cannot locate anywhere in my online Microsoft Account where to do so. My user pin and fingerprint aren't being recognized. Can anyone help?
any solution?
I have created a feedback on the hub, as my boyfriend had locked his laptop in fear that it was lost and we've essentially had a brick for over two months now. I really feel like they need to fix the lack of an "unlock" button or make it very clear the consequences of locking it. I've found posts from years back, so this is a longstanding issue that I truly feel needs prioritized, yet did not see any feedback.
If possible, please vote on the issue so it can get a resolution:
https://aka.ms/AAtrvbo
¿Pudiste solucionarlo?
EDIT: More context, my device was still locked after a reset. Solution below allows your data to be preserved, and should be the first thing tried before resetting the computer.
Couldn't find a solution anywhere for this myself. Since this is the latest thread on the topic I will post the solution that worked for me here.
- Restart device while holding shift to enter Windows Recovery Environment. Troubleshooting > Advanced Options > Open CMD. This is where you will need your recovery key.
- After CMD is open, type "regedit" and hit enter.
- Click "HKEY_LOCAL_MACHINE", then "File" in top left corner, then "Load Hive".
- A file explorer should appear. It should be "System32" as the folder already. If not, follow: This PC > (C:) Drive > Windows > System32
- Expand "HKEY_LOCAL_MACHINE" > expand folder "1234" > Microsoft > WindowsNT > CurrentVersion > PasswordLess > Device.
- Double click "DevicePasswordBuildVersion" from window beside file directory. Change value data from '2' to '0'.
- Restart computer by exiting the Recovery Environment.
- Should now have access to "Sign-In Options" on the sign in page. Choose "Sign-In with Microsoft Account" and use your account details.
- Everything should be back to normal, you will have to create a PIN again if you so choose, following the usual steps in settings.
Pretty ridiculous to have this option available without clearly informing the user of the ramifications, and the inability to unlock your device once found.
I tried this but under windowsNT > current version there is only a language pack. What can I do there?
Thank you for being one of the most helpful solutions I found here. When I got here. This really is ridiculous.. However I ran into an issue if you could please help??
When I got to step 6. And had to type "1234" I got an error saying cannot access the file because it's being used by another process. I don't understand it.. I never had a password on my pc.
Please help. I really don't want to wipe my PC. I had no idea this little "lock" button couldn't be reversed.. god this is dumb..
