i just did that and i still cant connect anything to Bluetooth also i dont get what that did
how do i fix my wifi/drivers problem and Bluetooth
i just built my pc and i got a pc protector app I'm not really sure what is was called but it installed a Wi-Fi driver for my pc before i could not use Wi-Fi only ethernet and when i tried to download my motherboard drivers it installed but it didn't change any thing i tried a lot of different ways for the drivers to work but not a single way worked anyways i have Wi-Fi now but it cuts out a lot when I'm playing a game or just idle and it happens mostly when I'm playing a game ere and i want to fix this but i don't know how to if someone could help me id really love that here my specs B650 Aorus Elite Ax AM5 motherboard CPU Ryzen 5 7600x operating system windows 11 home and also i can't connect any Bluetooth devices to my pc
2024-08-03T09:34:41+00:00 -
DaveM121 936.1K Reputation points Independent Advisor2024-08-03T07:44:31+00:00 I think now, since nothing else has solved this, the best option will be to perform an in-place repair with the Windows 11 ISO.
Please follow the steps, this is then not like re-installing Windows, it is just like an update and your personal files, settings and installed software will not be affected.
Click this link:
https://www.microsoft.com/en-us/software-downlo...
to download the Windows 11 ISO
When the ISO file completes downloading
Disconnect from the Internet
Disconnect all external devices with the exception of a mouse or keyboard.
Temporarily disable any 3rd party Anti-virus you may have installed
Then, in Windows File Explorer, double click the ISO and then run Setup.exe and select the Install option.
2024-08-03T07:41:17+00:00 it keeps trying to connect and i dont see any errors
DaveM121 936.1K Reputation points Independent Advisor2024-08-03T07:34:45+00:00 Is there an error dialog when you try to connect a Bluetooth device to your PC?
2024-08-03T07:30:22+00:00 the bluetooth is on but i still cant connect anything to my pc
