how do i fix my wifi/drivers problem and Bluetooth
2024-07-28T07:48:28+00:00
i just built my pc and i got a pc protector app I'm not really sure what is was called but it installed a Wi-Fi driver for my pc before i could not use Wi-Fi only ethernet and when i tried to download my motherboard drivers it installed but it didn't change any thing i tried a lot of different ways for the drivers to work but not a single way worked anyways i have Wi-Fi now but it cuts out a lot when I'm playing a game or just idle and it happens mostly when I'm playing a game ere and i want to fix this but i don't know how to if someone could help me id really love that here my specs B650 Aorus Elite Ax AM5 motherboard CPU Ryzen 5 7600x operating system windows 11 home and also i can't connect any Bluetooth devices to my pc
  1. DaveM121 936.1K Reputation points Independent Advisor
    2024-08-03T07:19:35+00:00
    That is okay, that indicates the Bluetooth drivers are now installed correctly, what happens if you try to pair a Bluetooth device to your PC, what error do you see?
    2024-08-03T07:12:26+00:00
    it shows this and it still wont connect and bluetooth has been on this entire time also i dont see any errors dont mind the picture on the bottom![Image](https://learn-attachment.microsoft.com/api/attachments/b03dd3d2-1b66-4a9e-a0a5-404debb1f946?platform=QnA
  3. DaveM121 936.1K Reputation points Independent Advisor
    2024-08-03T06:50:49+00:00
    If you go to the Settings App - Bluetooth and Devices, is the Bluetooth switch active on that page, can you turn it on/off or is that button greyed out?
    2024-08-03T06:34:06+00:00
    i deleted that probably right before i sent out the post
  5. DaveM121 936.1K Reputation points Independent Advisor
    2024-08-03T06:21:27+00:00
    I think this is caused by that AVG Tune Up app that you used, is that now uninstalled from your PC, because that can install corrupt and incompatible drivers.
