Is there a solution to fix my cursor lock when using Xbox game bar?
2024-07-17T00:07:24+00:00
So for a couple weeks (about 3 weeks now) anytime I use xbox gamebar on windows 11 to join a party to talk to some friends, my cursor lock on all applications would break making my mouse cursor go to another monitor when working on something or playing a game. This still happens when the application is fullscreen or borderless full screen. I confirmed it is the xbox gamebar as I have no other problems with cursor lock when I don't use the gamebar. All my updates, drivers, and apps are up to date and repaired/not broken. currently I'm using a app that will manually lock the cursor to a screen, but would rather not need to do so. Hopefully this is enough info, if not I can clarify more.
Windows for home | Windows 11 | Gaming
    2024-11-11T15:20:24+00:00
    Perfect ill try it when i get home. Could you maybe give some steps on how to uninstall the update im relatively new to computers so any help would be great. Also how would we know when the problem is solved,
    2024-11-07T14:58:29+00:00
    Probably why i didn't see it on my quick test lol just done a quick little test on 3600 dpi on sensitivity 8 and understand what you mean although it seems to of been worse before i uninstalled that update unless activision was aware of the issue and made an update to make the mouse jump back quicker.
    2024-11-07T14:24:30+00:00
    It also unlocks the mouse on Black ops 6. However, the mouse gets teleported back to the center of the screen. If you turn fast enough, you can see your mouse entering the other monitor briefly.
    2024-11-07T14:15:59+00:00
    just got home from work and thought the exact same thing and can confirm does work.
    Edit works fine on some games ie Black ops 6 but try to play destiny the issue is there so game dependent lol.
    2024-11-06T15:23:06+00:00
    repaired this 3 didn't fix it for me :(
    edit: also updated them to the latest versions still the same issue so this is not working for me :\
