G Pro X Wireless plays mute/unmute sound when audio starts or volume is changed
2024-10-24T20:33:55+00:00
I'm having this issue since updating to Windows 11 24H2, I've talked to Logitech support and they said since this is only happening on my PC and not others, its a Windows 11 update issue.
Here is what they said:
I understand your concern. I request you to contact Windows support as you are facing the issue after the Windows 11 update. There are high chances of audio drivers not updated properly. Hence, if you contact Windows support they will help you reinstall the software.
Please advise on how I should proceed, I've also linked a Reddit post with people having the same issue:
https://www.reddit.com/r/LogitechG/comments/1fml5oz/g_pro_x_wireless_plays_muteunmute_sound_when/
No one has found a solution yet
regards,
Taimur Ansari
2025-03-30T14:14:14+00:00
Fixed w/ KB5053656 3/27/2025.
78 additional answers
    2024-12-18T09:19:52+00:00
    Same issue here with pro X that's so bad!
  2. Deleted
    2024-12-06T08:07:58+00:00
    How choosing different device helps me to solve the problem????? I need to use my headset and microphone! If i choose always listen from the device, i will always hear my voice when im talking online with anyone. That IS NOT a workaround if you need your mic.
    Is this like an Indian L1 guy trying to be useful? Sorry but you are not. Microsoft should look at this as soon as possible and find a solution to fix this issue!!!!!
    2024-12-05T17:09:48+00:00
    Happening for me too, Logitech PRO X Wireless - mute/unmute sound when not listening to anything for like 1 Minute, then this sound occures when i play anything (starting video on youtube or anything that has sound). Nothing helped me to fix this, this seems like microsoft windows update issue. Fix it!
