Here is the latest setup log --
https://1drv.ms/u/c/368eb4378be4cf9d/EZmZyYd9051Bo9_9rwjTfzcBhHvsdzZBbiQjC3i1jwg3Kg?e=5THdrB
Also, I still haven't found GenuineTicket.xml in the Panther folder.
My PC crashed frequently due to a faulty memory stick. When I used a new memory stick, the problem didn't occurred anymore. Unfortunately, the crash also occurred during the windows update after the in-place upgrade. Until now, I have been unable to download and install two important updates -- the latest cumulative update and the update from August. (Two error codes (0x80070643 and 0x800f0805) appeared alternately)
I just tried Windows update troubleshooter and get a diagnosis --
WaaSMedicService
Issue found by :WinRETargetingPlugin
Problem with BITS service : The requested service has already been started. More help is available by typing NET HELPMSG 2182
Also, I've tried to perform the second in-place upgrade but ended in failure, an error occurred during the process(More details at https://answers.microsoft.com/en-us/windows/forum/windows_10-update/error-in-downloading-windows-10-cumulative/6ec330e1-c849-4b83-97db-286974f4290a?messageId=84f7d351-326d-49d5-8c7a-d154d5a69c89)
I hope all problems can be fixed without losing any data, please help me with a targeted solution as much as possible! Thanks!
I think they're built-in Microsoft Print to PDF and XPS drivers. They can be left alone.
It shows error removing some packages when I try to force delete prnms009.inf and prnms001.inf.
What should I do for next step?
Yes. Removing NVidia graphics drivers will force Windows to revert to Microsoft Basic display. For now, you can leave the Nvidia graphics drivers intact.
