WaaSMedicService problem -- Issue found by :WinRETargetingPlugin
2024-10-11T21:01:47+00:00
My PC crashed frequently due to a faulty memory stick. When I used a new memory stick, the problem didn't occurred anymore. Unfortunately, the crash also occurred during the windows update after the in-place upgrade. Until now, I have been unable to download and install two important updates -- the latest cumulative update and the update from August. (Two error codes (0x80070643 and 0x800f0805) appeared alternately)
I just tried Windows update troubleshooter and get a diagnosis --
WaaSMedicService
Problem with BITS service : The requested service has already been started. More help is available by typing NET HELPMSG 2182
Also, I've tried to perform the second in-place upgrade but ended in failure, an error occurred during the process(More details at https://answers.microsoft.com/en-us/windows/forum/windows_10-update/error-in-downloading-windows-10-cumulative/6ec330e1-c849-4b83-97db-286974f4290a?messageId=84f7d351-326d-49d5-8c7a-d154d5a69c89)
I hope all problems can be fixed without losing any data, please help me with a targeted solution as much as possible! Thanks!
  1. Ramesh 181.8K Reputation points Volunteer Moderator
    2024-10-12T12:49:44+00:00
    Unfortunately, I'm unable to get the latest chipset drivers , device drivers and bios .etc, my PC is too old, the official Manufacturer site no longer provides them for downloading.
    Could you please tell me how to get the them? What should I do if I'm unable to get them?
    It can be challenging to install 22H2 on legacy systems with older BIOS.
    Please use Driver Store Explorer to uninstall unused and obsolete driver packages. Before deleting the drive packages, export them using these commands from an admin Command Prompt.
    md c:\drivers
    dism /online /export-driver /destination:c:\drivers
    Re-run the setup and share fresh logs.
    2024-10-12T11:49:12+00:00
    I didn't find any latest chipset drivers and device drivers in official Manufacturer site.
    What should I do for next step?
  3. Ramesh 181.8K Reputation points Volunteer Moderator
    2024-10-12T11:38:48+00:00
    Unfortunately, the log doesn't mention the reason for the error code. Please try the following:
    1. See if there is a BIOS update for your device (Aspire M1860). The current BIOS is old.
                                  Manufacturer: Acer
                                  Model : Aspire M1860
                                  BIOS name : BIOS Date: **12/08/11** 17:24:15 Ver: 04.06.04
                                  BIOS version : P01-A4
                                  BIOS release date : 20111208000000.000000+000
    2. Install the latest chipset drivers and device drivers.
    3. Use Driver Store Explorer to uninstall unused and obsolete driver packages.
    4. Re-run the setup and share the latest logs.
    2024-10-12T11:19:00+00:00
    Here are the folders you mentioned above --
    https://1drv.ms/u/c/368eb4378be4cf9d/ESiPrTRBcgJEgoLC_Lb-7mEBWSbuqtHld7ywGPL4ZeErPQ?e=2Ga8aR
    Also, I didn't find GenuineTicket.xml in the Panther folder.
  5. Ramesh 181.8K Reputation points Volunteer Moderator
    2024-10-12T03:25:40+00:00
    Please share your setup logs.
    • Open the "C:$WINDOWS.~BT\Sources" folder.
    • Select the two folders, "Panther" and "Rollback" (if present).
    • Delete the GenuineTicket.xml file in the Panther folder.
    • Copy the two folders to the desktop and Zip them.
    • Upload the zip file to OneDrive and share the link here.
    (How-To: Share OneDrive files and folders - Microsoft Support)
    Share OneDrive files and folders - Microsoft Support:
    https://support.microsoft.com/en-us/office/share-onedrive-files-and-folders-9fcc2f7d-de0c-4cec-93b0-a82024800c07
    OneDrive sharing options - https://imgur.com/a/vZyxpY9
