Download the Nvidia drivers from that support page for your laptop, can you get that version of the drivers installed?
I need help. My graphics card isn’t found in Device Manager, replaced by Microsoft Basic Display Adapter with error code 31. Is the card possibly damaged? There should be an NVIDIA GeForce RTX 2050."
2024-11-27T11:35:32+00:00 i installed the last update
what is next -
DaveM121 936.1K Reputation points Independent Advisor2024-11-27T09:19:10+00:00 This is the official support page for your laptop, check if the BIOS version they provide needs to be installed,.
Then also try installing the Nvidia drivers they provide on that support page.
https://www.asus.com/laptops/for-gaming/tuf-gam...
________________________________________________________
Standard Disclaimer: This is a non-Microsoft website. The page appears to be providing accurate, safe information. Watch out for ads on the site that may advertise products frequently classified as a PUP (Potentially Unwanted Products). Thoroughly research any product advertised on the site before you decide to download and install it.
Deleted
DaveM121 936.1K Reputation points Independent Advisor2024-11-27T09:13:57+00:00 Okay, I will find that for you, click your Start Button, then jsut type msinfo and press Enter, please provide a screenshot of the resulting System Information window.
