I need help. My graphics card isn’t found in Device Manager, replaced by Microsoft Basic Display Adapter with error code 31. Is the card possibly damaged? There should be an NVIDIA GeForce RTX 2050."
2024-11-27T07:56:17+00:00
    2024-11-27T09:12:49+00:00
    can you help me
    how can I find  support page on my laptop
  2. DaveM121 936.1K Reputation points Independent Advisor
    2024-11-27T09:10:17+00:00
    Thank you for the screenshot, go to the support page for your PC on the manufacturers website, then from there, check if there is any BIOS update available that may need to be installed, then try re-installing the Nvidia drivers again.
    2024-11-27T09:08:33+00:00
    that is the screenshot and my device is laptop
    2024-11-27T09:06:37+00:00
    yeah , I did that
  5. Deleted
