Issue with Microphone Volume with Intel SST on Windows 11 24H2
2025-01-22T12:38:06+00:00
Hello everyone,
I’m using a ThinkPad X1 Extreme Gen 5 and recently ran into an issue after upgrading to Windows 11 version 24H2. The microphone volume is incredibly low, making voice communication nearly impossible on apps like Discord or during calls.
After thorough troubleshooting, including reinstalling Windows, I identified the problem: a compatibility issue between Windows 11 24H2 and Intel Smart Sound Technology (SST) audio drivers. The "Audio Enhancements" option, typically found under System > Sound > Microphone Properties, is also missing in this version.
When I revert to Windows 11 version 23H2, the microphone works perfectly, and the "Audio Enhancements" option reappears. However, updating to 24H2 causes the issue to resurface, which aligns with previous reports of Intel SST causing compatibility problems on Windows 11.
I submitted feedback through the Feedback Hub app, but I haven’t received any updates or acknowledgment yet. For now, I’ve reverted to version 23H2, but I hope Microsoft and Intel can address this with a driver update or patch soon.
If anyone has found a workaround or has more information, please share it here.
Thank you!
    2025-04-22T09:45:07+00:00
    This suggests its a config somewhere and probably something that is universal to sound input devices.
    I have been in contact with Lenovo on this, and they are asking me to reimage my BIOS to fix, the above suggests to me that a BIOS fix will not work, so will abort on that.
    Someone at MS will know exactly whats going on here, IMO
    2025-04-21T20:00:37+00:00
    Unfortunately not...
    2025-04-21T12:49:30+00:00
    still nothing from microsoft?
    2025-03-27T08:37:32+00:00
    So.... The last cumulative update for 23h3 broke the driver, so I'm out of options now... If the driver still works for you, I suggest that you block all updates except security ones.
    2025-03-17T20:42:45+00:00
    Just for you to know, I updated to 24H2 today, but the driver still wasn't available.
    Let's go back to 23H2 once again, I guess...
