Ethernet unplugged - > not connected/cable unplugged
2019-09-21T12:41:51+00:00
Like the title says, it says ethernet unidentified and then unplugged all within 2 seconds and it keeps happening again, and again, I can fix this by going to adapter properties then qos packet scheduler - > configure - > advanced and change speed & duplex to 10mbps half or full. However when I do this it remains constant unidentified network and I cannot access the Internet. Was most likely after an update and I have no system restore and uninstalling the update tells me undoing changes. Please help. Thanks.  PS after I do the qos packet scheduler thing and use the troubleshooter it says ethernet doesn't have a valid ip configuration. I've watched tens of hundreds of videos to fix this problem yet it remains unfixed. Please help thank you.
    2019-09-26T01:17:03+00:00
    Microsoft 10 Pro 10.0.18362 build 18362
    Motherboard is a b360m aorus gaming 3-cf
    2019-09-25T17:39:25+00:00
    Looking forward to your update.
    2019-09-25T17:30:49+00:00
    It's custom built. I'm not near my pc anymore will reply tomorrow. Thanks for the help
    2019-09-25T17:29:20+00:00
    Hi vurple
    What is the exact make and model?
    Open Start, type: system information
    Hit Enter
    Click System summary
    Look in the right pane
    Copy the system sku info into reply here.
    See example: https://imgur.com/qzektpA
    If its custom built, what is the make and model of the motherboard?
    2019-09-25T17:26:38+00:00
    Windows also isn't detecting my gpu or D drive now.
