Ethernet unplugged - > not connected/cable unplugged
2019-09-21T12:41:51+00:00
Like the title says, it says ethernet unidentified and then unplugged all within 2 seconds and it keeps happening again, and again, I can fix this by going to adapter properties then qos packet scheduler - > configure - > advanced and change speed & duplex to 10mbps half or full. However when I do this it remains constant unidentified network and I cannot access the Internet. Was most likely after an update and I have no system restore and uninstalling the update tells me undoing changes. Please help. Thanks.  PS after I do the qos packet scheduler thing and use the troubleshooter it says ethernet doesn't have a valid ip configuration. I've watched tens of hundreds of videos to fix this problem yet it remains unfixed. Please help thank you.
    2019-09-26T14:46:58+00:00
    Hi vurple
    I am beginning to think this is a compatibility issue with your configuration and Windows 10 1903.
    My recommendations:
    File a bug report and wait until Windows 10 1909 is released with a potential fix:
    File a bug report; send me the short link so I can vote on it and bring it to the attention of the Windows engineers in my capacity as a Windows Insider MVP.
    See instructions how to file the bug report.
    https://windows10.help/blogs/entry/54-how-to-su...
    Information in the above link is sourced from a trusted Microsoft MVP blog.
    OR
    Downgrade to Windows 10 1809
    Step 1: Download Windows 10 1809 from the following link:
    https://tb.rg-adguard.net/index.php?sid=74a7cf5...
    Choose the following:
    • Windows Final
    • Windows 10, version 1809
    • Windows 10 Pro + Home
    • English
    • x64 (64 bit) x32 (32 bit)
    Step 2: create a bootable copy
    https://answers.microsoft.com/en-us/windows/wik...
    Step 3: perform a custom install
    http://answers.microsoft.com/en-us/insider/wiki...
    Step 4: how to recover your files from Windows.old:
    https://answers.microsoft.com/en-us/windows/for...
    Windows Update might attempt to upgrade to Windows 10 1903 again. See instructions how to block it:
    https://www.groovypost.com/howto/block-windows-...
    Note: This is a non-Microsoft website. The page appears to be providing accurate, safe information. Watch out for ads on the site that may advertise products frequently classified as a PUP (Potentially Unwanted Products). Thoroughly research any product advertised on the site before you decide to download and install it.
    2019-09-26T11:19:18+00:00
    I downloaded and installed the intel proset adapter configuration utility, i believe that also updated my adapter drivers, still not working.
    2019-09-26T11:12:25+00:00
    When i tried to install bios drivers, it said something about 16 bit application not being compatible (i clicked autoexecute)
    when trying to install the intel drivers, it says missing oemver.reg
    2019-09-26T10:57:12+00:00
    Should I download them on laptop and apply them on pc? Would that work?
    2019-09-26T01:49:18+00:00
    I see some important updates available for your make and model.
    BIOS Update June 2019
    http://download.gigabyte.us/FileList/BIOS/mb_bi...
    LAN Driver January 2019
    http://download.gigabyte.us/FileList/Driver/mb_...
    Apply these updates to see if they help.
