Ethernet unplugged - > not connected/cable unplugged
2019-09-21T12:41:51+00:00
Like the title says, it says ethernet unidentified and then unplugged all within 2 seconds and it keeps happening again, and again, I can fix this by going to adapter properties then qos packet scheduler - > configure - > advanced and change speed & duplex to 10mbps half or full. However when I do this it remains constant unidentified network and I cannot access the Internet. Was most likely after an update and I have no system restore and uninstalling the update tells me undoing changes. Please help. Thanks.  PS after I do the qos packet scheduler thing and use the troubleshooter it says ethernet doesn't have a valid ip configuration. I've watched tens of hundreds of videos to fix this problem yet it remains unfixed. Please help thank you.
    2019-09-27T17:02:18+00:00
    thanks mate, thanks for all your help too.
    2019-09-27T15:53:45+00:00
    Glad you got it resolved vurple.
    2019-09-27T11:44:38+00:00
    It doesn't have pro or home, it just says windows 10, is that fine?
    2019-09-26T17:37:55+00:00
    Keep us updated with your progress vurple.
    2019-09-26T17:37:06+00:00
    Alright I'll try and reinstall windows 1809 tomorrow
