I ended up reinstalling windows 10 from scratch and deleting all partitions. And it's still not working. I've tried this computer on a different connection with ethernet and it works. I've also tried the ethernet at home with my laptop and it works. Why isn't it working with ethernet at home?
Ethernet unplugged - > not connected/cable unplugged
Like the title says, it says ethernet unidentified and then unplugged all within 2 seconds and it keeps happening again, and again, I can fix this by going to adapter properties then qos packet scheduler - > configure - > advanced and change speed & duplex to 10mbps half or full. However when I do this it remains constant unidentified network and I cannot access the Internet. Was most likely after an update and I have no system restore and uninstalling the update tells me undoing changes. Please help. Thanks. PS after I do the qos packet scheduler thing and use the troubleshooter it says ethernet doesn't have a valid ip configuration. I've watched tens of hundreds of videos to fix this problem yet it remains unfixed. Please help thank you.
2019-09-25T17:21:03+00:00 -
2019-09-21T20:33:59+00:00 Ok I understand
2019-09-21T18:54:02+00:00 I'm good I've dealt with this enough thanks for all your help. I'll just give it to a repair shop or something. Thank you
2019-09-21T18:15:17+00:00 Then you will have to do the new installation as I told you before but removing the partitions and re-creating them
2019-09-21T18:13:56+00:00 Factory reset doesn't work. It starts and when it gets to 100% it then goes to undoing changes and that a problem occurred or something.
