You can also do a factory reset of the PC
Ethernet unplugged - > not connected/cable unplugged
Like the title says, it says ethernet unidentified and then unplugged all within 2 seconds and it keeps happening again, and again, I can fix this by going to adapter properties then qos packet scheduler - > configure - > advanced and change speed & duplex to 10mbps half or full. However when I do this it remains constant unidentified network and I cannot access the Internet. Was most likely after an update and I have no system restore and uninstalling the update tells me undoing changes. Please help. Thanks. PS after I do the qos packet scheduler thing and use the troubleshooter it says ethernet doesn't have a valid ip configuration. I've watched tens of hundreds of videos to fix this problem yet it remains unfixed. Please help thank you.
2019-09-21T18:06:34+00:00 -
2019-09-21T18:05:21+00:00 then you will have to borrow a USB and make a completely new installation, but before installing I recommend you to delete the Disk partitions and recreate them
2019-09-21T18:03:24+00:00 "windows 10 installation has failed"
2019-09-21T17:56:52+00:00 Ok, I'll be attentive
2019-09-21T17:55:31+00:00 Installing windows 10, your pc will restart several times, thanks I hope it works too, will update soon.
