Ethernet unplugged - > not connected/cable unplugged
2019-09-21T12:41:51+00:00
Like the title says, it says ethernet unidentified and then unplugged all within 2 seconds and it keeps happening again, and again, I can fix this by going to adapter properties then qos packet scheduler - > configure - > advanced and change speed & duplex to 10mbps half or full. However when I do this it remains constant unidentified network and I cannot access the Internet. Was most likely after an update and I have no system restore and uninstalling the update tells me undoing changes. Please help. Thanks.  PS after I do the qos packet scheduler thing and use the troubleshooter it says ethernet doesn't have a valid ip configuration. I've watched tens of hundreds of videos to fix this problem yet it remains unfixed. Please help thank you.
    2019-09-21T15:55:34+00:00
    My PC has no internet. and is that really necessary?
    2019-09-21T15:50:57+00:00
    Ethernet actually works on my laptop and not my pc. Great.
    2019-09-21T15:31:16+00:00
    The cable unplugged message is almost always a hardware problem.  Check that the RJ45 plugs seat well on both your computer and the switch or router.   Try a different cable also.  And try a different port on the switch.
    I'm surprised at the fact that forcing 10mbps has an effect. That implies to me that maybe some pins on the cable have a marginal connection.
    2019-09-21T15:22:45+00:00
    I recommend you repair Windows completely before you should make a copy of your files.
    https://answers.microsoft.com/en-us/windows/for...
    2019-09-21T15:17:22+00:00
    your isp got to get your computer a new ip Address before get back on the internet
    disable your firewall take off all the software you do not need any more that will help your computer out.
