With the link I sent you will repair Windows completely, and yes, you can transfer your files to the phone and then transfer them back to the PC.
Ethernet unplugged - > not connected/cable unplugged
Like the title says, it says ethernet unidentified and then unplugged all within 2 seconds and it keeps happening again, and again, I can fix this by going to adapter properties then qos packet scheduler - > configure - > advanced and change speed & duplex to 10mbps half or full. However when I do this it remains constant unidentified network and I cannot access the Internet. Was most likely after an update and I have no system restore and uninstalling the update tells me undoing changes. Please help. Thanks. PS after I do the qos packet scheduler thing and use the troubleshooter it says ethernet doesn't have a valid ip configuration. I've watched tens of hundreds of videos to fix this problem yet it remains unfixed. Please help thank you.
2019-09-21T16:22:48+00:00 -
2019-09-21T16:15:24+00:00 I've already tried resetting the pc and it always ends up in undoing changes, are you positive this would work? also, how would i put the files on that pc is it possible i can put it on my android phone as a transfer? then plug it into the pc and transfer it there since i do not have a usb?
2019-09-21T16:03:22+00:00 Then download the ISO from another PC, and the copies on the PC that does not have internet and you run the repair.
2019-09-21T15:56:39+00:00 my desktop was fine until a few days ago when i installed the update. :(
2019-09-21T15:56:11+00:00 Interent works fine on laptop phone and everything its just my main desktop thats experiencing issues.
