Windows resource protection found corrupt files but was unable to fix some of them for online repairs details are located in cha log file located at~
Ethernet unplugged - > not connected/cable unplugged
Like the title says, it says ethernet unidentified and then unplugged all within 2 seconds and it keeps happening again, and again, I can fix this by going to adapter properties then qos packet scheduler - > configure - > advanced and change speed & duplex to 10mbps half or full. However when I do this it remains constant unidentified network and I cannot access the Internet. Was most likely after an update and I have no system restore and uninstalling the update tells me undoing changes. Please help. Thanks. PS after I do the qos packet scheduler thing and use the troubleshooter it says ethernet doesn't have a valid ip configuration. I've watched tens of hundreds of videos to fix this problem yet it remains unfixed. Please help thank you.
2019-09-21T15:14:58+00:00 -
2019-09-21T15:08:26+00:00 No, after executing all
2019-09-21T14:53:20+00:00 after executing the commands you restart the PC, and you re-execute the first steps that you indicate to repair the Internet
2019-09-21T14:50:50+00:00 Did all of them except sfc scan doing it now.
2019-09-21T14:48:39+00:00 The first command said the component store is available, whereas the second one said dism failed no operation was performed error 0x8024402c I'll do the 3rd one now
