Ethernet unplugged - > not connected/cable unplugged
2019-09-21T12:41:51+00:00
Like the title says, it says ethernet unidentified and then unplugged all within 2 seconds and it keeps happening again, and again, I can fix this by going to adapter properties then qos packet scheduler - > configure - > advanced and change speed & duplex to 10mbps half or full. However when I do this it remains constant unidentified network and I cannot access the Internet. Was most likely after an update and I have no system restore and uninstalling the update tells me undoing changes. Please help. Thanks.  PS after I do the qos packet scheduler thing and use the troubleshooter it says ethernet doesn't have a valid ip configuration. I've watched tens of hundreds of videos to fix this problem yet it remains unfixed. Please help thank you.
    2019-09-21T14:47:06+00:00
    I will be attentive
    2019-09-21T14:40:47+00:00
    This is taking quite a long time possibly a few hours
    2019-09-21T14:00:50+00:00
    You can use the System File Checker tool to repair damaged system files.
    Follow these steps:
    Press the Windows + X keys and select Symbol of the System (Administrator) or Windows PowerShell (Administrator), in the window that will open, you must type the commands in their respective order:
    • DISM.exe /Online /Cleanup-image /Scanhealth
    • DISM.exe /Online /Cleanup-image /Restorehealth
    • DISM.exe /online /cleanup-image /startcomponentcleanup
    • sfc /scannow
    Each of these actions may take a few minutes, so it is important to execute one at a time. At the end, you must restart the PC.
    Check this link:
    https://support.microsoft.com/en-us/help/929833...
    2019-09-21T13:43:37+00:00
    Also when I rebooted after network reset the Internet icon goes back to the WiFi with the x and then ethernet with triangle. And continues this process
    2019-09-21T13:42:11+00:00
    Thanks aracely. First off when I do ipconfig/renew it says no operation etc while it has its media disconnected.
    After that I close cmd and do flush dns and reboot nothing occurs. It doesn't give me the option to restart dns in services. And I have also reset my network. To no avail.
