I have found a solution.
Just download the offical Audigy RX driver from Creative website.
Extract it with Winrar or other tool. Manually install the driver from the folder Audio -> DriversWin10 -> wdm -> browse wdm_emu.inf file.
If installed succesfully, then just restart the PC.
Step 2.
Download the Audigy Support Pack from https://drive.google.com/file/d/0B4veZnyFbxW4VjdhUVMzOG1yVFE/view, or from the website: http://danielkawakami.blogspot.com/2017/01/sb-audigy-series-support-pack-62.html
Extract it. Then run Setup. Choose Custom install. Uncheck the Driver. Install all other App. Restart PC, and Audigy 2 ZS is working.
All apps working. Speaker Settings, EAX Console, Audio Console
Thank you.
I've uninstalled driver installed and using autoruns i've removed entries in drivers and services related to creative.
I've dowmloaded the .exe (SBA5_PCDRV_L11_3_01_0056B.exe) in one directory. Went to audio\driverswin10\wdm\
And right click on wdma_emu.inf , select install.
Reboot windows,
now I've sound working on my Windows 10 version 1903.
