update 1903 sound problem
2019-03-23T14:32:25+00:00
I have just updated to 1903, and have lost all sound. I have a Creative Audigy2 ZS Pro, yes, I know it's old, but it was working perfectly on build 1809.
After this 1903 update, no sound, so I went back to 1809, and hey presto, I got my sound back. I then tried the very latest 1903 build, but lost the sound again. Have MS got an answer? I will have to go back to 1809 if I want to hear anything, but can wait a day or so if anyone at MS can give me a solution.
    2021-01-25T20:03:17+00:00
    I'm interested in this bit that you wrote  "and using autoruns i've removed entries in drivers and services related to creative. "
    becuz.  windows is not letting me uninstall the driver ( keeps crashing ).
    what is the autoruns feature you speak about.  thanks.
    2020-11-25T11:18:06+00:00
    Is there any way to fix this issue with an Sound Blaster Audigy Platinum EX? I followed instructions here but nothing seems to be working, this card with the box was working fine until I updated this week to 1903 , I thought the issue was solved so I upgraded and now I don't have audio anymore , any other advice?
  3. Deleted
  4. Deleted
    2020-05-18T08:53:52+00:00
    Do you have mainboard soundcard installed too? If so, uninstall their drivers and disable it on BIOS.
    If you can make a clean windows install I would try it.
