update 1903 sound problem
2019-03-23T14:32:25+00:00
I have just updated to 1903, and have lost all sound. I have a Creative Audigy2 ZS Pro, yes, I know it's old, but it was working perfectly on build 1809.
After this 1903 update, no sound, so I went back to 1809, and hey presto, I got my sound back. I then tried the very latest 1903 build, but lost the sound again. Have MS got an answer? I will have to go back to 1809 if I want to hear anything, but can wait a day or so if anyone at MS can give me a solution.
    2020-05-18T08:39:27+00:00
    I tried this on my Audigy 2 Platinum EX.  It appeared to work in that I got sound from of the card but it produced an intermittent strange sound that made it unusable.
    2020-05-17T17:07:16+00:00
    I have found a solution.
    Just download the offical Audigy RX driver from Creative website.
    https://support.creative.com/Products/ProductDetails.aspx?catID=561&catName=Sound%20Cards&subCatID=1123&prodID=21723&prodName=Sound%20Blaster%20Audigy%20Rx&_ga=2.220384088.1563738097.1557985768-1807327002.1557156356#
    Extract it with Winrar or other tool. Manually install the driver from the folder Audio -> DriversWin10 -> wdm -> browse wdm_emu.inf file.
    If installed succesfully, then  just restart the PC.
    Step 2.
    Download the Audigy Support Pack from https://drive.google.com/file/d/0B4veZnyFbxW4VjdhUVMzOG1yVFE/view, or from the website: http://danielkawakami.blogspot.com/2017/01/sb-audigy-series-support-pack-62.html
    Extract it. Then run Setup. Choose Custom install. Uncheck the Driver. Install all other App. Restart PC, and Audigy 2 ZS is working.
    All apps working. Speaker Settings, EAX Console, Audio Console
    IT WORKS ON "AUDIGY 2"!!!
    I downloaded the Audigy RX Windows 10 driver like said here, extract with WinRAR. I updated the Audigiy 2 driver from Device Manager, restarted the PC and now I have sound and all works correctly! (I had previously installed Support Pack 6.2, I didn´t need to install it after the Audigy RX driver installation).
    THANKS YOU VERY MUCH!!!
  3. Deleted
  4. Deleted
    2020-04-11T00:35:51+00:00
    so this is the solution..tx
    I tried that but it didn't work for me.
