Creative SB Audigy 2 ZS driver issue - NO SOUND- after Windows 1903 update
2019-04-30T16:57:58+00:00
Just updated to 1903, and have lost all sound,I know it's old soundcard, but it was working perfectly on build 1809/1803/1709/1703/1607..
2019-06-02T20:38:50+00:00
Hi!
This worked for my Creative Audigy 2 ZS and Windows 10 1903 update:
https://extreme.pcgameshardware.de/windows-7-8-1-und-10-windows-allgemein/540331-win-10-update-1903-soundblaster-kein-ton.html?highlight=audigy
Download "Audigy RX Driver" from Creative
Extract all files
Go to the folder "Audio\DriversWin10\wdm"
Right-click "wdma_emu.inf" and select "install"
Restart and enjoy!
Best regards!
Markus
73 additional answers
    2019-11-13T02:19:30+00:00
    i cant find Audigy RX Driver ISO formate and cant find any Extract file from creative
    2019-11-09T23:42:03+00:00
    Thank you man! You are a hero!
    2019-11-08T16:18:07+00:00
    Believe it or not: after several unsuccesfull attempts early 2019 to install windows 10 on my old Medion PC, which uses Creative Audigy 2 ZS as soundcard, yesterday it happened with 1903 and the sound of Creative. Updating simply from W7 Prof 32 bits via Microsoft Media Tool to W10 Prof 32 bits, the sound is back in! And the old videocard NVIDIA 7650 is no longer needed since MS installed a video adapter. Respect! Everything is running perfectly now again! Danke Microsoft!
    2019-11-05T16:17:07+00:00
    Thanks!  This worked for me.  I ran into the same problem with the *.exe file auto-running and stopping when it detected my card was the older version.  7Zip did the trick.  I extracted the *.exe file and navigated to the correct folder and installed wdma_emu.inf.
