Creative SB Audigy 2 ZS driver issue - NO SOUND- after Windows 1903 update
2019-04-30T16:57:58+00:00
Just updated to 1903, and have lost all sound,I know it's old soundcard, but it was working perfectly on build 1809/1803/1709/1703/1607..
2019-06-02T20:38:50+00:00
Hi!
This worked for my Creative Audigy 2 ZS and Windows 10 1903 update:
https://extreme.pcgameshardware.de/windows-7-8-1-und-10-windows-allgemein/540331-win-10-update-1903-soundblaster-kein-ton.html?highlight=audigy
Download "Audigy RX Driver" from Creative
Extract all files
Go to the folder "Audio\DriversWin10\wdm"
Right-click "wdma_emu.inf" and select "install"
Restart and enjoy!
Best regards!
Markus
73 additional answers
    2019-11-22T10:06:54+00:00
    Affirmative, problem solved.
    2019-11-19T22:06:11+00:00
    Works like a charm. Thank you!
    2019-11-17T19:01:07+00:00
    Hey man,
    you saved my day.
    I skipped the 19xx releases till now. Today installed 1909 and .... silence.....
    Thank you so much. My Audigy2 works now as before with that driver.
    Sebastian
    (daniel.k sb driver pack 6.2)
    2019-11-15T15:51:36+00:00
    Just for info: my driver is Creative 6.0.1.1304 from 22.02.2008, working perfectly
