Creative SB Audigy 2 ZS driver issue - NO SOUND- after Windows 1903 update
2019-04-30T16:57:58+00:00
Just updated to 1903, and have lost all sound,I know it's old soundcard, but it was working perfectly on build 1809/1803/1709/1703/1607..
2019-06-02T20:38:50+00:00
Hi!
This worked for my Creative Audigy 2 ZS and Windows 10 1903 update:
https://extreme.pcgameshardware.de/windows-7-8-1-und-10-windows-allgemein/540331-win-10-update-1903-soundblaster-kein-ton.html?highlight=audigy
Download "Audigy RX Driver" from Creative
Extract all files
Go to the folder "Audio\DriversWin10\wdm"
Right-click "wdma_emu.inf" and select "install"
Restart and enjoy!
Best regards!
Markus
73 additional answers
    2019-07-31T11:22:52+00:00
    Hi!
      Thanks for the tip. It really works, but only for playback. Any recording source doesn't work, it doesn't return any error of any kind, but it just doesn't record (mic, what u hear, aux., etc.), it has no signal at all.
       It is sad, because this sound card is very good, it has a great sound quality and the recording WAS also great.
    Thanks again.
    2019-07-23T02:23:56+00:00
    Works like a charm!!
    Thanks man!
    Creative Audigy 2 ZS + Windows 10 64bits - 1903 build.
    2019-06-15T02:39:30+00:00
    It works for me. Thanks!
    "Creative Audigy 2 ZS and Windows 10 1903 update"
    2019-04-30T17:00:38+00:00
    Hello, I am an independent consultant willing to help.
    Thank you for publishing your question, please open the following Microsoft thread where you will be presented with all the information and a permanent solution to your problem, follow the steps and instructions that appear there:
    https://answers.microsoft.com/en-us/windows/for... one
    This is the link that is provided there
    Problem with the Creative SB Audigy 2 ZS driver: NO SOUND, after the Windows 1903 update
    I hope this information solve your problem, I will be attentive to any comments.
    Best regards,
    Cristhian
