Audio problem on Logitech Z Cinema after October Update
2018-10-03T21:26:38+00:00
After installing October Update on Windows 10 volume control is not working (using Logitech Z Cinema speakers through USB).
Driver update, restart explorer, restart Windows Audio service didn't help.
Any suggestion ?
    2019-03-16T15:51:10+00:00
    I confirm the result! +++
    after a "hard reset process" - turn off power Z-Cinema - power outage (while the speakers played!!!) mechanically switched off the power - everything works correctly !!!
    Thank's for help (tired of reinstalling Windows with all driver's ((( - lost all weekend)
    2019-03-15T15:16:37+00:00
    Hola,
    Después de instalar la actualización de octubre en Windows 10, el control de volumen no funciona (usando los altavoces Logitech Z Cinema a través de USB).
    Actualización de controladores, reinicio del explorador, reinicio de Windows El servicio de audio no ayudó.
    ¿Alguna sugerencia?
    Gracias
    Descargar en logitech Z cinema el sistema 32 bit. Eso soluciona el problema.
    2019-03-14T17:05:30+00:00
    Thank you so much Microsoft for fixing the problem.
