Hi Winnie5560,
In Device Manager, right click that device and choose 'Disable' - don't uninstall it as Windows will just re-install it.
That should stop the popups you are getting !!
What is this? Under device manager, Imaging Devices, shows orange exclamation mark; tried to update but here is information under Properties:
This device cannot start. (Code 10)
The specified request is not a valid operation for the target device.
Device ROOT\IMAGE\0001 was deleted.
Class Guid: {6BDD1FC6-810F-11D0-BEC7-08002BE2092F}
I also tried troubleshooting under Hardware & Devices but problem is unresolved. Can I uninstall this?
Hi Winnie5560,
usb\vid_0482&pid_061d&mi_01
Olá, acabei excluindo sem querer o 260ci WIA (USB) Driver, tenho como recupera-lo ou baixa-lo em algum lugar?
Thank you
