Hi Winnie5560,
In Device Manager, right click that device and choose 'Disable' - don't uninstall it as Windows will just re-install it.
That should stop the popups you are getting !!
What is this? Under device manager, Imaging Devices, shows orange exclamation mark; tried to update but here is information under Properties:
This device cannot start. (Code 10)
The specified request is not a valid operation for the target device.
Device ROOT\IMAGE\0001 was deleted.
Class Guid: {6BDD1FC6-810F-11D0-BEC7-08002BE2092F}
I also tried troubleshooting under Hardware & Devices but problem is unresolved. Can I uninstall this?
Hi Winnie5560,
Glad to help, if you have any more questions, please contact us here at MS Community!
Hi Dave,
Thanks so much for the assistance.
I have disabled the 260ci WIA Driver USB on Device Manager.
In Windows Defender, Device Performance & Health, Device Driver- the message is gone!
Hopefully, this will stay resolved.
Hi Winnie5560, do you have a Kyocera printer or printer/scanner?
If so you need to reinstall the software and driver for that device . . .
If you have a Kyocera device what is the Model No. of that device
Hi Winnie,
That guid refers to a camera or more likely a scanner . ..
Right click that device in Device Manager, choose Properties
Click on the Details Tab and change the Property Drop down to Hardware ID's
Right click the top line in the resulting list and choose Copy
Paste that line in here and I will help with identifying that device . . .
