Hi Winnie5560,
In Device Manager, right click that device and choose 'Disable' - don't uninstall it as Windows will just re-install it.
That should stop the popups you are getting !!
What is this? Under device manager, Imaging Devices, shows orange exclamation mark; tried to update but here is information under Properties:
This device cannot start. (Code 10)
The specified request is not a valid operation for the target device.
Device ROOT\IMAGE\0001 was deleted.
Class Guid: {6BDD1FC6-810F-11D0-BEC7-08002BE2092F}
I also tried troubleshooting under Hardware & Devices but problem is unresolved. Can I uninstall this?
Hi Winnie5560,
Hi Dave,
Everything is working well on my printer. I checked Programs & Features and I can't find a Kyocera printer/scanner in the que. The only issue is that I keep getting pop ups from Windows Defender Security Centre, Device Performance & Health, Device Driver message: "One or more devices may not be working properly. Run the Hardware Device Troubleshooter to try and resolve this." After running the troubleshooter, the issue persists. It's not a major issue, just annoying.
Hi Winnie, before doing anything, is everything on your PC ans Printer working as expected?
If everything is working properly, then do nothing, since that is a Kyocera Printer driver, it is more than likely that Windows Update has made a mistake in installing that driver - leave well enough lone - it is not doing harm where it is !
Hi Dave,
I do not have a Kyocera printer/scanner; not sure if I ever had one! I currently have a Canon Image Class printer/scanner. Do you think it would be safe to uninstall this from Device Manager?
Thanks.
Hello Dave,
Thanks for your prompt response.
Here is the info:
usb\vid_0482&pid_061d&mi_01
