Battery Draining In Alcatel Idol 4S
2018-01-27T15:52:58+00:00
I have an Alcatel Idol 4S with windows 10 and when it is not being used the battery drains completely in one day. What is causing this?
    2019-04-17T16:29:07+00:00
    Mine is:
    Alcatel Idol 4S with Windows 10 NA
    OS build: 10.0.15254.562
    Firmware revision number: 1052.16.09031.50700
    Hardware revision number: 0.0.0.3
    2019-04-12T14:39:13+00:00
    Alcatel Idol 4 Pro firmware 1052.16.10011.51400, build 10.0.15254.562
    2019-04-12T14:14:44+00:00
    Thanks, Carl. If anyone else is interested, if you will post specifics such as carrier, firmware rev. no., o/s build, etc., I'll see if I can compile it all and then maybe we can compose a tweet that will prompt some action and start tweeting it out there.  We might even get some reinforcement in the Twitter sphere... Might be fun.
    I don't know when I'll be able to get to it... maybe between all these battery 🔋 drain/shutdown episodes 😏 .
    ...and just FYI, while searching for info online about the battery drain issue, from what I saw, it looks like there have been battery drain issues with Win10 on several devices, not just phones. Many were described as o/s issues.
    2019-04-12T13:03:41+00:00
    Firmware
    1052.10.0831.54600
    OS
    10.0.15254.562
    I stil have have  same phone problems. It will lose power and drop to 6%
    2019-04-12T00:41:52+00:00
    I hit the problem once, but it has not repeated.
    I'm on a 4S ATT
    10.0.15254.562
    1052.16.09031.50700
    If I wanted to get MS Attention to this thread and issue, then pick a day and time (Universal) and send the thread as a link in tweets to @Windows.  To get attention to any issue, you need to take IRL tactics and apply to VR.  5 or 10 different people reporting within a few minutes will wake people up.
    Many thanks for posting that @Erwin247, good to know.
    now...  Anyone else up to the task?  Sounds like we need to gang up and coordinate this.
    I'm not a tech person and don't
    know about "IRL tactics" or how to "apply to VR" so need someone to explain.
