Battery Draining In Alcatel Idol 4S
2018-01-27T15:52:58+00:00
I have an Alcatel Idol 4S with windows 10 and when it is not being used the battery drains completely in one day. What is causing this?
    2019-04-12T00:21:15+00:00
    I hit the problem once, but it has not repeated.
    I'm on a 4S ATT
    10.0.15254.562
    1052.16.09031.50700
    If I wanted to get MS Attention to this thread and issue, then pick a day and time (Universal) and send the thread as a link in tweets to @Windows.  To get attention to any issue, you need to take IRL tactics and apply to VR.  5 or 10 different people reporting within a few minutes will wake people up.
    2019-04-09T21:51:57+00:00
    My alcatel idol 4 pro is a very nice device, the little glitsch hen sudenly the battery level drops to 6% I solved by having a powerbank close by , connect it to the powerbank.very short and th old battery level has recovered. Just to fool the os. At the moment I am running 10.0.15254.562
    Thanks for the info.  Thats a bit different than mine, maybe due to different carriers?  I'm with T-Mobile.  If you don't mind, will you post the firmware revision number please?
    2019-04-09T21:04:44+00:00
    2019-04-09T20:54:27+00:00
    Alcatel idol 4 pro 10.0.15254.562
    2019-04-08T21:01:45+00:00
    @CarringtonTV, also, do you mind posting the software version you have, after you reset and updated?
