Processor maximum speed locked at 0.76 GHz
2014-05-27T00:04:11+00:00
EDIT: The problem seems to have been fully resolved by doing a clean install of Windows 10.
I use an AMD A6 processor on my Lenovo IdeaPad Flex 15D. Recently, my PC has been slow, and checking the Task Manager shows that the processor speed is only 0.76-0.78 GHz, while my processor's maximum speed is 2.00 GHz. The Resource Monitor says that my maximum frequency is 38-39% (0.76-0.78 GHz). This happens even when I'm in High Performance mode, and I've checked to make sure that the minimum and maximum speeds (in the power options) are set to 100%. I've also set the ATI Powerplay settings to Maximize Performance. The speed does not increase even when I'm running many programs at once.
Any help would be very appreciated.
I've noticed something interesting... The CPU speed in the Task Manager always seems to hang around 0.7-0.78 GHz, even when I'm not doing anything else on my laptop. Perhaps there's something that is not only preventing it from going above 0.78 GHz, but preventing it from going below 0.7 GHz. I have no idea why this is happening.
2014-05-27T00:22:00+00:00
You need to check with Lenovo Support, their on-line documentation and drivers, and
ask in their forums about any known issues.
Lenovo Support and downloads
http://www-307.ibm.com/pc/support/site.wss/homeLenovo.do
Lenovo Forums
http://forums.lenovo.com/Hope this helps.
Rob Brown - Microsoft MVP <- profile - Windows Expert - Consumer : Bicycle - Mark Twain said it right.
61 additional answers
    2016-11-07T16:00:51+00:00
    It isn't just Lenovo, I'm working on an HP 15 Notebook. Had to swap out the hard drive, did a factory restore from an HP restore USB drive of Windows 8.1. Clean install, amd I'm having the issue as well.
    2016-10-21T21:59:29+00:00
    I'm gonna try that , i have a dell inspiron 11 too btw
    EDIT : Didn't really work :( stayed at 0.76
    2016-10-21T21:58:35+00:00
    Hey.
    I Have the same thing , Max processor speed locked at 0.76-0.78 , if anyone can solve this , please do reply
    By the way i had this problem when i had windows 10 , now i got windows 8.1 so yeah , starting all over again won't work :(
    EDIT: i forgot to say that i had 8gb ram and maximum speed of 2.30 GHZ
    2016-07-27T12:53:50+00:00
    I have this same issue on a Dell Inspiron 11 after a Windows 10 upgrade. It happens even when I'm 100% on battery and the adapter is not plugged in. The only thing that seems to fix it (temporarily) is going into hibernation and coming back out.
