Nokia Lumia 930 microphone problem
2014-07-24T13:10:38+00:00
Hello.
I got an issue with my Lumia 930 that i bought today.
 When i've got an incomming/outgoing call the person on the other end can't hear me, but i can hear them clearly. It works when i put the call on speaker, but i want to be able to call someone and not sharing the conversation with everyone around me.
So far i've done:
Soft reset
Hard reset
Nokia Software recovery tool
Does anyone have this issue?
Is there a fix for this or should i return it?
    2014-12-28T02:52:45+00:00
    yes..i also have this type of problem in my Lumia 930, have any way can fix it?
    CCLebie wrote:
    Hello.
    So far i've done:
    Soft reset
    Hard reset
    2014-12-23T10:42:48+00:00
    Hi! you can try to play a music through headset and while playing the music remove the headset then restart the phone. Possible that the grounds for the speaker has messed up.
    2014-12-23T00:31:44+00:00
    It doesn't work for me, even if that was the problem that cannot be a solution for a 4G phone. Insane.
    2014-12-12T11:28:39+00:00
    Thankyou Niel12, problem fixed... Thankyou so much..!
    2014-12-12T11:23:50+00:00
    Niel12, you mean changing highest connection speed to 2G....???
