No chance. I'm in Argentina and I brought the phone in Brasil, no Nokia Care in Argentina as long as I know. Sadly I will have to wait for another solution.... I cant believe it's not yet fixed by MS widely...
Nokia Lumia 930 microphone problem
Hello.
I got an issue with my Lumia 930 that i bought today.
When i've got an incomming/outgoing call the person on the other end can't hear me, but i can hear them clearly. It works when i put the call on speaker, but i want to be able to call someone and not sharing the conversation with everyone around me.
So far i've done:
Soft reset
Hard reset
Nokia Software recovery tool
Does anyone have this issue?
Is there a fix for this or should i return it?
2015-05-11T16:19:31+00:00 -
RedSpook-9082 4,765 Reputation points Volunteer Moderator2015-05-11T13:13:13+00:00 Don't wait, take it to a Nokia Care facility and have it repaired/replaced under warranty.
2015-05-11T13:00:46+00:00 Well, I did the recovery tool thing, and nothing happened. Tried before getting the updates and restoring the backup and nothing. the mic does the same 10% of volumen recording as before. It's funny, but I got GDR2 in the updating process, which I didn't have before, but it didn't solve the mic issue. It is definitely a Lumia 930 issue that could only be solved with a specific 930 update. Maybe W10? Don't wanna wait that much! I need to use Skype and they can't listen to me!!! HEEEELLLP MS!!!!
2015-05-08T16:08:40+00:00 Thank you for your answer, Im trying to do the recovery tool thing, besides in the first post someone already tried this without success. In the main screen of the tool it shows that my firmware is number 02540 and the server versión is 02061, which look rather old. I guess after the recovery the phone will automatically update to the latest version, is it right? I did a backup. Is firmware 02061.00066.14252.51001 correct for Lumia 930?
2015-05-07T21:57:16+00:00 Hi, mcphistot. Welcome to Microsoft Mobile Community. Have you tried checking if all system apps on your phone are up to date? Go to Settings> applications> store> check for updates. If in case all system apps are updated, you can try using the Windows Phone Recovery Tool. This may fix minor issues you are experiencing on your phone. The link is applicable to your phone regardless of your location.
We'll wait for your reply.
