2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2014-08-27T17:07:29+00:00
    It would help if you specified which product you were offering this solution for.  E.g. it doesn't help me with my Surface RT 2.   There is still no support for toggling off any functions of its "screen cover" which is where its touchpad is.
    In my case, I know that I have disabled the touchpad on my Surface RT 2.  I'm just not sure how and I wish that I had a way of toggling it back on because having a more precise pointer device than my finger or one of those ridiculously bulky and imprecise capacitive pens would often be helpful.  But only if it was easy to toggle back off again.
    Oh.  It's not as arcane as I had imagined, actually straightforward, just many steps, instead of being a "toggle".  FWIW here are the steps to Enable the Disabled Touchpad.
    1. Press Win-w and find and open Mouse (that is the only word in the item and it may not appear without scrolling the list)
    2. In Mouse Properties tap on the Hardware tab
    3. See Device status:  This device is disabled: (Code 22)
    4. Tap Properties
    5. Tap (Administrator) Change settings
    6. Tap Enable Device
    7. See Device Problems Troubleshooting Wizard ask:  "Do you want to enable this device?"
    8. Tap Next
    9. See Windows successfully enabled this device.
    10. Tap Finish
    11. Move your pointer via your Touchpad as proof that your "toggle" has succeeded.
    So, for any Surface RT user who wants to disable the Touchpad in their "screen cover", the steps to reverse that result should be obvious.  Perhaps the same steps or a simple variation of them will help any other Touchpad owner who does not have any UI support for their device.
    FYI
    Robert Aldwinckle
