2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2014-08-28T05:19:28+00:00
    the steps to Enable the Disabled Touchpad.
    I think most of the pain of doing that was the first step, finding the Mouse Properties.  So I found a tip about expediting that.   This works on my Surface RT to get directly into the Mouse Properties Hardware tab.  On my Surface Pro it only opens up to the first tab (normally labeled Buttons) probably because I have Microsoft Mouse and Keyboard Center installed and it takes over the first tab.
    C:\Windows\System32\rundll32.exe shell32.dll,Control_RunDLL main.cpl,,4
    So, I created a Desktop shortcut with that in it and pinned it to my Start Screen.   Now I will be able to at least start the above procedure more directly.
    C.f.
    http://www.sevenforums.com/tutorials/143549-mouse-properties-shortcuts-create.html
    (BING search for
        "mouse properties" "main.cpl"
    I actually first landed on the EightForums  with that search but couldn't use the tips there regarding the MUF Settings (better) alternatives.   Maybe the Surface screen cover will eventually be supported as a "modern" device.   ; }
    I still intend to have a go at creating a real toggle for this.  On the Surface Pro there is a lot more possibility for automating this using various keyboard macro tools for scripting support than on the RT.
    Edit:  Now I'm finding that I need to use  ,,3  instead on the RT?  WTH?  Have I lost a tab?  It's the Wheel!  I had an ArcTouch Mouse attached when I first started testing.   Oops.
