2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2014-08-12T03:10:32+00:00
    Many of you may be like me because all of the options above did not work (either you don't have synaptics, or your mouse options from the control panel don't show trackpad options, or your model doesn't have a special app to control the mouse/trackpad). t
    There may still be hope! I've found two other options to try.
    1. Go the Start screen or desktop and swipe on right side to get the charms. Select "settings" which is bottom charm. From settings options select "change pc settings." This brings up the Personalization app. I'm not on the right laptop now to tell you which section is the right section but on my RT device, this is where I was able to turn off the Click to Tap functionality. Sometimes it comes back on with updates so I have to come back and turn it on/off again/
    2. There is an app in the app store called "Trackpad Settings" - I downloaded that on the laptop i'm using right now and it worked to turn off Click to Tap. However, this does not work on Surface Pro with the new Type 2 cover. it did work on a Dell and a Lenovo.
    hope this helps.
