2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2014-06-03T22:11:57+00:00
    You STILL don't understand!  WE don't want to DISABLE the track pad, only disable TAPPING which you could do in Windows 7!!!  Try it out one both systems, then reply with a correct answer, please!
