2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2014-06-03T07:54:24+00:00
    Exactly as per the above.
    Go to Toshiba website, enter product model for driver support, no drivers available or required for Windows 8. Brilliant, so I am stuck with a random jumping mouse as there is no way to turn off this feature
    2 minutes just to edit the above due to it jumping all over the place. Microsoft, sort this out. Clearly you are finding the touch pad as it is working its working too bloody well. Add the tapping feature to your default PS2 poining device if it finds one
    another two minutes on that and I cansn frustratioot be arsed going back to fix the spelling mistakes whereI have over deleted characters
    oh look I didn't even bother to sort the last one out
    Microsoft you really are letting your users down, we're looking at rolling out WTG 8.1 to potentially 70,000 users but this is going to be an issue
