2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2014-06-03T22:50:00+00:00
                disable TAPPING which you could do in Windows 7!!!
    So, figure out the difference.  E.g. if same hardware, it sounds like the manufacturer supplied a special package in W7 but in W8 you are just getting some kind of generic support.  Then you could see about the possibility of installing the W7 support for that device in compatibility mode.
    Otherwise, create your own toggle which disables and enables the device (or specific functions of it if you have that information).  FWIW I have been imagining that it might be possible to do that using WMIC which then would probably be pretty simple to automate by attaching it to a function key or at least by clicking on a Desktop shortcut.   Etc.
    Good luck
    Robert Aldwinckle
