2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2013-04-02T11:49:01+00:00
    OMG, I have been trying for two weeks. I cannot disable tapping on my mouse pad. There just simply is no way to do it. I loved windows 7, but 8 is a piece of junk. Seems like they have assumed to know what I will want and need in a computer. Then, blocked me out of any easy user control decisions. People had set down, and worked on ways to make really cool changes, not thinking of what the consumer might want. GIVE ME BACK MY WINDOWS 7.
