2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2013-03-16T23:31:51+00:00
    Sorry, I made a mistake in my first reply.  Search Trackpad from the start screen.  Then go to the Settings tab and open the Settings file.  Then uncheck all boxes to disable your track-pad.  I will change my first reply to what it should be.
    Are you using Windows 8?  None of these options are available to me.
