2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2013-04-02T20:27:22+00:00
    cannot disable tapping on my mouse pad. There just simply is no way to do it.
    Have you found the device yet in Device Manager?  Get some details that way.   As I mentioned you can at least disable the Touchpad entirely that way.   It may not be identified in any obvious manner,  e.g. it may only be listed under Human Interactive Devices or USB devices.  Also, it may help to use a different View, although I think the default one has the most detail.
