Ha, not where you think, try this:
Click, Start>>>Control Panel>>>Folder Options>>>General Tab>>>Click items as follows>>>Single click/Double click
HTH
If I brought you Joy, cast your Vote! If I answered your question, click, Propose As Answer! >WT<
How do I change the mouse click from double to single?
HTH
If you don't see folder options in the control panel, click on appearance and personalization, then folder options will be listed and change it to single click to open an item and point to select, save.
Do you want to always use a single click to open files, run programs, etc? If so:
Seems to keep moving around. Now under File Explorer Options > General
Click the start button or windows logo on the bottom left, and then on pictures,
On the top left side click on the organize listing, then click on folder and search options from this list,
On the general tab section click on single click to open and point to select, click on apply and okay.
This would be the answer if it really worked. Problem is, the "single click to open and point to select" checkbox is grayed out. I have the opposite problem. My Win7 PC suddenly started single click to open and point to select, but I want the reverse - single clicking for selecting, and double click for opening. In folder options it is set to double click for opening, but contrary to the setting, it opens files with single clicking anyway! Yet, the "single click to open and point to select" checkbox is grayed out and cannot be selected. Why?
