Change mouse double click to single click
2011-02-23T20:16:22+00:00
How do I change the mouse click from double to single?
  • Looked in Control Panel under "Mouse"
2011-02-23T20:24:24+00:00
Ha, not where you think, try this:
Click, Start>>>Control Panel>>>Folder Options>>>General Tab>>>Click items as follows>>>Single click/Double click
HTH
If I brought you Joy, cast your Vote! If I answered your question, click, Propose As Answer! >WT<
2011-02-24T01:34:50+00:00
If you don't see folder options in the control panel, click on appearance and personalization, then folder options will be listed and change it to single click to open an item and point to select, save.
2011-02-23T20:22:38+00:00
Do you want to always use a single click to open files, run programs, etc?  If so:
  1. Go to Control Panel > Folder Options .
  2. Under Click items as follows , select one of the Single-click options.
Boulder Computer Maven
Microsoft Most Valuable Professional
74 additional answers
    2017-10-22T17:04:17+00:00
    In WIN 10, just go to Cortana and type in Folder Options. That takes you to File Explorer Options.  In that window you are able to change from Double Click to Single Click and back.
    2011-06-20T22:03:05+00:00
    Click the start button or windows logo on the bottom left, and then on pictures,
    On the top left side click on the organize listing, then click on folder and search options from this list,
    On the general tab section click on single click to open and point to select, click on apply and okay.
