Ha, not where you think, try this:
Click, Start>>>Control Panel>>>Folder Options>>>General Tab>>>Click items as follows>>>Single click/Double click
HTH
If I brought you Joy, cast your Vote! If I answered your question, click, Propose As Answer! >WT<
How do I change the mouse click from double to single?
HTH
If you don't see folder options in the control panel, click on appearance and personalization, then folder options will be listed and change it to single click to open an item and point to select, save.
Do you want to always use a single click to open files, run programs, etc? If so:
I just bought a windows 10. I can not find how to single click. Can any one help me?
"GO TO CONTROL PANEL, THEN CLICK ON FILE EXPLORER OPTIONS, THEN CLICK ON SINGLE CLICK ON CLICK ITEMS AS FOLLOES"
Great answer!
This helped me immediately!
FYI: The 'Folder Options' is now called 'File Explorer Options'.
