Change mouse double click to single click
2011-02-23T20:16:22+00:00
How do I change the mouse click from double to single?
  • Looked in Control Panel under "Mouse"
2011-02-23T20:24:24+00:00
Ha, not where you think, try this:
Click, Start>>>Control Panel>>>Folder Options>>>General Tab>>>Click items as follows>>>Single click/Double click
HTH
If I brought you Joy, cast your Vote! If I answered your question, click, Propose As Answer! >WT<
2011-02-24T01:34:50+00:00
If you don't see folder options in the control panel, click on appearance and personalization, then folder options will be listed and change it to single click to open an item and point to select, save.
2011-02-23T20:22:38+00:00
Do you want to always use a single click to open files, run programs, etc?  If so:
  1. Go to Control Panel > Folder Options .
  2. Under Click items as follows , select one of the Single-click options.
Boulder Computer Maven
Microsoft Most Valuable Professional
74 additional answers
    2017-02-16T03:29:18+00:00
    You said it all when you say "it's not where you'd think".... cause I'd looked
    LOL
    THANX
    2017-02-10T19:07:42+00:00
    THANK YOU!!!
    I am running on a computer still using Vista Ultimate and it did not provide the info as the first 2-3 people said it would - so I kept reading!
    And you, madame or sir - solved my problem immediately!
    Please accept my gracious thanks  :)
