Ha, not where you think, try this:
Click, Start>>>Control Panel>>>Folder Options>>>General Tab>>>Click items as follows>>>Single click/Double click
HTH
If I brought you Joy, cast your Vote! If I answered your question, click, Propose As Answer! >WT<
How do I change the mouse click from double to single?
HTH
If you don't see folder options in the control panel, click on appearance and personalization, then folder options will be listed and change it to single click to open an item and point to select, save.
Do you want to always use a single click to open files, run programs, etc? If so:
I'm not given the option for folder options after going to control panel.
I guess I'm in the minority. I WANT double click and can't seem to get it changed back in W10. I selected the proper settings per the instructions above but no deal. Every time I move my mouse and click once on an icon, the damned program opens. HELP!
