Printer problem - Items sent to print are not printing.
2010-09-04T04:54:31+00:00
I'm having problems with my printer.  If I send a document over to be printed it doesn't print?  There's no jam, the cartridges are full and there's  paper.  Help!
2011-07-01T21:28:02+00:00
Hi Bob,
Getting a test page out is good start, but there a few thing s you can try to get your printer fully working...
Microsoft provides a Fix It tool which will troubleshoot the printer for you, and might give some useful information on what might be causing an issue:
http://windows.microsoft.com/en-US/windows-vista/Troubleshoot-printer-problems
If you are getting prints out it sounds as though there isn't much wrong with the spools service, but keep an eye on it as sometimes a print job can throw the service out. You'll find it in Services.
Also, make sure you have the latest driver for the printer from the manufacturers website. You view what drivers you have already from Print Management, which you can find in Administrative Tools from the Control Panel.
Hope some this helps.
96 additional answers
    2011-10-05T05:33:27+00:00
    I have the same problem with my printer, did you manage to get your printer printing again?
    2011-10-05T05:25:44+00:00
    My printer Epson ESC/P Standard 3 is ready to print on the Printers and Faxes program but the ink light on the printer stays on even after I replaced all the cartridges with new ones
    2011-09-25T11:18:09+00:00
    Hi Airidh,
    When logged into your Answers account, you can do the following:
    Towards the top of the Answers site, click Ask a question
    Type in your question then click Ask
    This will take you to a new screen which will possibly show other similar questions and for you to finish asking your question.  Please be sure to include as much detail as possible in the Details section.
    You can then select your Windows OS, and Submit.
    Hope this helps!
    2011-09-22T20:39:35+00:00
    Hi Debbie
    So how do I start a new thread?  Probably obvious to everybody except me ....
    Thanks.
